I have a idea! :)
Dakkar
I have a idea! :)
Post by Dakkar »
I just want to share a idea I have to better integrate Essentials to HB.
My problem is to execute HB task from essentials, but without having to use the module connector.
I have been reading about the jump method, but it seems that in this way you change the module you are in. (For example, if I am in the media module and with a mapped key I jupm to a command module, I will leave the media module).
So what about this:
1) From whithin the screen you execute a girder event.exe command
2) Girder reacts to this event with a command that change the state of a property of a X10 device
3) HB starts a task in reaction to this property change.
Do you think it could work? These are my doubts:
1) Can HB and Girder work togheter on the same CM11A?
2) I need girder to change a not relevant property of a device. I mean, in HB I would have used a fake non hardware device... How can I do with real device? Does not important properties exist for X10 devices?
mmm... The alternative is to do everything with girder, but I don't know how to do that (expecially to control the SW10 to lower a projector screen to a EXACT height...)
What do you think about?
Dakkar
Can you just use the HouseBot External Control device and call HB_Control.exe instead of going through Girder using event.exe?
Dakkar
Post by Dakkar »
ScottBot wrote:Can you just use the HouseBot External Control device and call HB_Control.exe instead of going through Girder using event.exe?
Simply because I didn't know it existed! :)
Now I found it and it is very useful!!!
Thank you very much Scott!
Dakkar
