SmartHome 2814UB interface
joegr
Post by joegr »
I had hoped that the new SmartHome PowerLinc USB interface modem number 2814UB would work, but it doesn't seem too. It is the newest version of the PowerLinc USB and it adds INSTEON support. (I am not looking for the Insteon features to work at this point, just the old fashioned X10 stuff.) I don't think that they sell the non-insteon version anymore, or I would have gotten that one. Anyway, I have verified (using SmartHome's program) that it does work on the computer I am trying to use this on.
Below is what SmartHome's program says about the interface.
Device Type: INSTEONPLC-USB
FIRMWARE: 2.12
DEVICE PORT: USB4
DEVICE ADDRESS: 00.D5.9B
Below is a sample dump from SmartHome's programs log file. It shows some commands received, and some being sent.
downloadTimer started
timerActivate enabled
SDM:DM=active,1.00.134.134,12/30/2005 4:16:38 PM,responded,00.D5.9B,2.12
ui:!isresponding
PLC:isresponding=True
ui:!getplcstatus
PLC:getPLCstatus=beginlist
port=USB4
connected=True
firmware=2.12
id=00.D5.9B
devicetype=InsteonPLC-USB
lastErrorMsg=#0:
endlist
ui:!setclock=12/30/2005 04:16:39 PM
PLC:setClock=OK
PLC:saladapp=busy
PLC:eventraw=FD
PLC:eventraw=FE
PLC:eventraw=FD
PLC:eventraw=FE
PLC:saladapp=free
PLC:eventraw=08
PLC:receiveX10raw=00 AA
PLC:receiveX10=D4
PLC:eventraw=08
PLC:receiveX10raw=01 A2
x
PLC:eventraw=08
PLC:receiveX10=D4
PLC:eventraw=08
PLC:receiveX10raw=01 A3
ui:!sendx10=A9,AOn
PLC:sendx10=True,A9,AON
ui:!sendx10=A9,AOff
PLC:sendx10=True,A9,AOFF
ui:!sendx10=A9,A0%
PLC:sendx10=True,A9,A0%
ui:!sendx10=A9,A0%
ui:!sendx10=A9,A27%
PLC:sendx10=True,A9,A26%
ui:!sendx10=A9,AOff
Last, but not least, here is what the InterfaceTrace file had. (Note that I removed the stuff in the middle, it was just more of the same repeated lines. This includes attempts to enable the interface, and attempts to set the retry property.)
Dec 30 2005,01:45:42PM,Unable to find the USB PowerLinc Device.
Dec 30 2005,01:45:46PM,--> Getting Status
Dec 30 2005,01:45:46PM,"Write File Error [The handle is invalid.
Dec 30 2005,02:42:45PM,--> Getting Status
Dec 30 2005,02:42:45PM,"Write File Error [The handle is invalid.
Dec 30 2005,02:42:45PM,Timeout waiting for PowerLinc to become idle.
Dec 30 2005,02:42:46PM,"Write File Error [The handle is invalid.
Dec 30 2005,02:42:49PM,Unable to find the USB PowerLinc Device.
If it is possible to get this going and you need any other info that I might could provide, let me know.
Joe
Joegr
Joe,
I imagine that there may only be some minor changes that Meedio would need to make to the existing Powerlinc plugin to support the new version. It obviously needs to recognize the newer USB product ID.
Although this won't help you right now, I'm going to be sharing my Hardware Interface and Insteon device plugins that work with the new Powerlinc. I'm leveraging the Smarthome SDM (the same thing you generated your trace with) which makes it much easier to develop than going to the USB and serial ports directly. After the Insteon stuff is working, I plan on adding X10 support to the plugin too. I don't have so much time these days, so I'm not sure exactly when that will be. However, by using the SDM module provided by SmartHome, it makes it MUCH easier to add the support.
