I have several Zwave devices in my network. I initiated them with the remotecontrol and duplicated the remote to my USB interface. Worked great.
Now, if I want to add more devices, how do I go about doing that without messing up my Housebot configuration?
Any tips are appreciated!
Zwave, adding more devices to the USB controller?
Just add the devices as normally to the network using the ZWave remote. Then transfer the remote to the USB controller as you did initially. It will overwrite the exiting config. Since you have only added new ZWave devices, the existing node ID's will remain the same and will still match what you have configured in HouseBot.
Then you can create new Devices in HouseBot for the switches you have added to the zwave network. You can either hit the "Create HouseBot Devices..." button in the zwave hardware interface config, or just create them manually.
