Software remote won't run on CE 5.0
Posted: Mon Mar 06, 2006 9:01 pm
by tgaerke
I have a 8" VGA industrial touchscreen that has CE 5.0 with a "i486" processor in it. I cannot get any of the software remote clients to run on it. I get the following error when I try to launch SWRemote. 'SWRemote' is not a valid Windows CE Application. I have had success getting SWRemote running on a dell pocket pc running Pocket PC 4.2. Any suggestions??
Posted: Tue Mar 07, 2006 7:13 pm
by PT
Try the fake dll.s.used for 4.1 & 4.2 and make a shortcut on the desktop
Posted: Tue Mar 07, 2006 9:30 pm
by tgaerke
I downloaded the fake dll's and put them in the windows directory. I then tried to launch all the different version of the SWRemote by clicking on them in file explorer. I didn't try to make a shortcut on the desktop. I will try that tomorrow.
Just to make sure I am handling the fake dll's properly, all I need to do is copy all of them into the windows directory??
Posted: Wed Mar 08, 2006 4:39 am
by PT
Hi
Yes,put dll's into windows directory and then make a shortcut on desktop.
Other option is using webpage with com.You can make it look like homeseer.
Good luck.
tried suggestions, still not working
Posted: Thu Mar 09, 2006 12:22 pm
by tgaerke
I tried copying the dll's and making the shortcuts and none of the clients work. I think the problem here is that this is CE 5.0 and not Pocket PC. Couple that with the fact that the processor is a x86 not a arm, mips, or sh3 and who knows??
I am curious as to what you meant by "com" and make it look like homeseer. I can get this touchscreen to ping my housebot pc and I can view webpages. Base on this capability, any other ideas?
Posted: Thu Mar 09, 2006 1:56 pm
by PT
Hi
Well,Housebot has a com interface which means you can bascally have a webpage on a server and call that webpage from any machine that has a network connection. The webpage can activate any of the properties and pretty much emulate the software remote.
If you pm me with an email address I can send a picture for you to look at with basic bits on.One advantage is you can use. animated giffs etc.
