Winamp Plugin
Winamp Plugin
Is there any way to extract album art from the ID3v2 tag? I want to use dynamic images to display album art, but I think I'm missing something. Has anyone done this. Also, using the Winamp plugin, what is the technique for going to next song and previous song in playlist. I realize I need to increment the playlist song number, how do I do this without using a vbscript?
Re: Winamp Plugin
If you want to do it from a theme, use a simple property change button and set the "New Value" for the button press to +=1 or -=1. Here's an old sample (attached - make sure you are logged in to see it) for WinAmp that may help. If I remember correctly, it does all this. Just drag and drop the attachment onto HouseBot and restart.incoronado wrote:what is the technique for going to next song and previous song in playlist. I realize I need to increment the playlist song number, how do I do this without using a vbscript?
- WinAmp_Sample.hbx
- WinAmp Sample import
- (4.49 KiB) Downloaded 274 times
Any ideas about displaying album art out of ID3v2 tag of the currently playing song? Also, How would you approach a gauge that indicates the percentage of a song played? I can do this with a script, but I thought that would be fairly CPU intensive if it was triggered on a change to Song Position. My guess is that I will need the power a script nad will have to convert Song Length and Song Position to seconds. I always like to use HB internal abilities to do things if at all possible. It's much faster and safer. Is there a way to basic arithmetic using a form of subsitution or is += and -= the extent of it?
