Any thought to having an embedded web browser? I was poking around on the MS site today, and it seems like something like this might be possible-
http://msdn.microsoft.com/library/defau ... _entry.asp
I'm guessing that I couldn't write this as a plugin, right?
It would solve a bunch of annoying things like live webcams. . .
Markd
Embedded web browser?
Re: Embedded web browser?
Not really. Plugins extend the functionality of the server, but don't help the SWRemotes. You could write something to spawn a browser on a SWRemote machine, but it wouldn't be embedded.markd wrote:I'm guessing that I couldn't write this as a plugin, right?
Markd
Technically, it may not be too difficult to have the browser embedded in the SWRemote (although I'm not certain how well it would work on WinCE platforms). However, would you want to control it somehow (other than specifying a URL) from the server as well? Or would the control come from the user interacting (or just viewing) with the control?
I can see a lot of utility in just specifying the URL- would work for the webcam issue. Might be nice to be able to set the scroll bars, so you could window into the correct part of a web page.ScottBot wrote: However, would you want to control it somehow (other than specifying a URL) from the server as well? Or would the control come from the user interacting (or just viewing) with the control?
I'm going to set up a touchscreen next to the couch for driving the theater stuff- one thing I'd like to have on it is IMDB access, with all the linking that implies. I could exit housebot to do it, but it would be nice to have it embedded.
Same thing for searching for recipes in the kitchen. Would also provide a quick and dirty (local webpage) way to do a phone number list.
Markd
How funny, I just built this.
It took me some time to get it to work on remote PC's as well so all SWRemotes can do their own thing without interferring with eachother. In that setup every SWRemote PC (in my case a PaceBlade) would have a separate HouseBot server which has a NULL device and a script device for only the browser. The NULL device is a copy from the main server and the script device points to the same browser script on the main server. On the main server, all remote browser null devices are replicated so they can be adressed from different themes on the main server. Each remote PC can access their unique theme on the main server. This keeps all functionality on the main server and creates unique browsers for each remote PC by using the replicator.
Be aware that in this setup all extra HB Server on the remote PC's would require an extra Registration Key and this option will cost money!!!!!! It works very well though.
If you want I can post my script here or in the scriptsection. It opens a small panel bar, has 7 favourites buttons which go unlimited deep per button, has GoBack, GoForward, Refresh and Stop buttons. Has a button to pop a virtual keyboard and an Exit button (Previous Panel).
The browser window is a standard IE COM object window in Fullscreen, so it only shows borders and no status, menu, tool bars etc. This can obviously be changed to own settings in the script. It opens on a set Top, Left, width, height and gets automatic focus whenever someone navigates back or forward etc since IE looses focus because SWRemote theme buttons are pressed.
Let me know if you are interested. I am not able to upload images now etc since I am still at work.
BTW, an ascii phonenumber list could easily be displayed in an alphalist using script. You could even select a phone number an display additional info on it like an address or even a picture using a dynamic image. I have this setup as well.
Since I'm headed to 4 touchscreen, that would be a bit expensive! If I was going to spend that much I'd have gone for CQC or Mainlobby.
I would be interested in the phone number script though!
I have been reading your movie and music scripts trying to get a handle on them- I was hoping that the MediaPro plugin was going to turn up and keep me from having to do the whole Meedio thing, but that isn't looking very likely.
Markd
Markd
Below the code.
It is a continuous running script and it can sort on number or name.
The phonebook ascii file looks like:
1234567890 vbTAB Name1 vbLF
0123456789 vbTAB Neme2 vbLF
Option Explicit
On Error Resume Next
Dim nit
Dim nic
Dim Action
Dim Sort
Dim TotalLines
Dim FileSystem
Dim StdIn
Dim FileName
Dim objRE
Dim strContent
Dim colLines
Dim PhoneBookLog
Dim Regel
Dim Temp
Dim PhoneName()
Dim PhoneNumber()
Do
Sleep 1
Action = GetPropertyValue ("Telefoon Status.PhoneBook Action")
If Action <> "Waiting" Then
SetPropertyValue "Telefoon Status.PhoneBook Action", "Waiting"
SetPropertyValue "Telefoon Status.Log PhoneBook", ""
Sort = GetPropertyValue ("Telefoon Status.PhoneBook Sort")
FileName = "C:\Program Files\XAN ISDN-Anrufbeantworter\Einstellungen\Telefoonboek.DAT"
PhoneBookLog = ""
Set FileSystem = CreateObject("Scripting.FileSystemObject")
Set StdIn = FileSystem.OpenTextFile(FileName, 1)
If Err.Number = 0 Then
strContent = StdIn.ReadAll
Set objRE = New RegExp
objRE.Global = True
objRE.Pattern = ("\n")
Set colLines = objRE.Execute(strContent)
ReDim PhoneName(colLines.count + 1)
ReDim PhoneNumber(colLines.count + 1)
TotalLines = 0
Do Until StdIn.AtEndOfStream
Regel = Split(StdIn.ReadLine, Chr(9))
PhoneNumber(TotalLines) = Regel(0)
PhoneName(TotalLines) = Regel(1)
TotalLines = TotalLines + 1
Loop
If Sort <> "Nummer" Then
For nit = 0 to TotalLines
For nic = nit + 1 to TotalLines
If PhoneName(nic) < PhoneName(nit) Then
Temp = PhoneName(nic)
PhoneName(nic) = PhoneName(nit)
PhoneName(nit) = Temp
Temp = PhoneNumber(nic)
PhoneNumber(nic) = PhoneNumber(nit)
PhoneNumber(nit) = Temp
Next
Next
Else
If PhoneNumber(nic) < PhoneNumber(nit) Then
Next
Next
For nit = 1 to TotalLines
PhoneBookLog = PhoneBookLog + PhoneName(nit) + "#" + PhoneNumber(nit) + vbTAB + PhoneName(nit) + vbTAB + PhoneNumber(nit) + vbLF
Next
StdIn.Close
Set colLines = Nothing
Set objRE = Nothing
Else
PhoneBookLog = vbTAB + "Geen telefoonboek datafile gevonden!"
Err.Clear
SetPropertyValue "Telefoon Status.Log PhoneBook", PhoneBookLog
Set StdIn = Nothing
Set FileSystem = Nothing
Loop
Thank you. I'm learning vbscript from your excellent examples.
I think I'm going to use an export from outlook to populate my data file- that way I can have one central point for maintaining phone numbers. That Split command should come in handy for the CSV file. I'm going to use the Categories fields to slice and dice the list down to a few different list properties- one for the kids, one for family, etc.
Thanks again!
Markd
Thanks again!
Markd
