How can I run 2 tasks at the same time ?
When I run a Task that calls a task the server Execute the called task and only when the Task is over it continues on with the actions.
Ofer.
Running 2 Tasks at the same time
- HouseBot Special Member
- Contact:
- Create a null device
- Create any property in that device
- Create an automatic task (when conditions are met) that tracks changes of the property that you created, and runs the first task that you want to run
- In the main task, change the propery that you created so that the automatic task will run. That will cause the first task to execute and continue.
- Call the second task
