Script Problem
jonkjon
Script Problem
Post by jonkjon »
Why doesn't this work...?
OpenPanel is an script device with an alpha property of Panel Name. The Panel Name property is set by a list control which does work in setting the Panel Name property to the name of a viable panel.
Dim panel
panel = getpropertyvalue ( "OpenPanel.Panel Name" )
OpenRemotePanel (panel)
If i put the name of a panel in quotes directly in the script, it works.......
Have you tried adding a
MsgBox "[" & panel & "]"
or something like that to verify that the panel name you are expecting is making it into the script?
You may also want to check the error log and see if there are any messages about it.
jonkjon
Post by jonkjon »
I tried the message box routine and the script is getting the correct panel name. There are no error messages in the logs either. I have found another way of doing what i need using a task but i still don't know why this script doesn't work.
jonkjon
Post by jonkjon »
I figured this out. When the Panel Name property gets set, there is an carriage return appended to the end of the string. If i use a string function to remove the carriage return, it works!
Thought it might be something like that. That's why I added the brackets in my MsgBox example.
Glad you figured it out.
jonkjon
Post by jonkjon »
Yeah, the brackets were the giveaway. Thanks alot for the quick reply...
