serial device disables on reboot
HB not saving serial devices enabled status on reboot. I have to go in and enable them on every reboot.
That's strange, mine are sticky. Can you test this: Enable, then stop the HB Server manually without a reboot and restart it again. What happens? If they are still enabled, what happens than after a reboot?
You can always write a script that interfaces with HB's own access database to enable your devices
Anyways, it should work. I have the latest version and did a reboot and all seems fine.
Exiting HB and loading it back without a reboot leaves them enabled. After a reboot they come back disabled. I just tested it. I'm running an 8 port octopus serial card. The ports do not change. All I have to do is to go into HB and enable without changing any other options to make it work after reboot. I'm beginning to think that I'm trying to load HB (loading automatically at boot) before the services are completely started.
That's strange. If it was last enabled when HB is closed, it will try and enable it on startup. If there is an error enabling it, it will set the enabled state to "No" so it won't try and do it the next restart (since some user interaction may be needed). But if this was the case, you would have seen an error.
