Win CE Registry
Win CE Registry
Scott:
What is Windows CE 5.0 Device\HKEY_LOCAL_MACHINE\SOFTWARE\CeBotics\HouseClient used for?
I am trying to persist a change in the directory that the SWRemote writes files to because Program Files\ is not an area that persists between power cycles on my device. I want to change it to Storage Card\ but I don't see a command line option for this. I presume this is saved in the registry and I can permanently alter the registry to reflect this.
Re: Win CE Registry
Nevermind....found it under USER\SOFTWARE.
Olser
Re: Win CE Registry
You should also be able to change that setting from the main configuration dialog on the SWRemote.
Re: Win CE Registry
Yes, but I want an auto login for the device and registry settings do not persist between powerups unless I manually set and save. Just needed to find them so I could do that.
