Unable to find property Device ID error
wetwired
Post by wetwired »
All of a sudden I´m getting this error on startup.
Unable to find device ID [84] in device list.
Unable to find property. Device ID = [84], Property ID = [36]
And I need to abort ignore or cancel. When I open the HBData.mdb in access device 84 is missing. How do I fix this?
Re: Unable to find property Device ID error
I take it you haven't backed up your database recently. If you have, drop a preserved copy of the .mdb file into the config folder and restart HB. Alternatively, use the restore feature under the file menu.
If restoring your configuration doesn't work, you can send me the HBData.mdb file and I'll see if there's anything I can do to help.
wetwired
Post by wetwired »
Scott, I have sent you the mdb file.
By the way, I got the RFXCOM device, testing it now...
