Apparently, HouseBot does not decode the low battery status with X10 DS10a door open/close sensors. Here's a W800RF32 interface trace for the normal case:
"1/15/2009","7:16:27 am","W800RF32","Debug","W800 received raw data [3f 30 04 fb]."
"1/15/2009","7:16:27 am","W800RF32","Debug","X-10 Security Command Received. CMD = [Sensor Open Min]. Unit = [48]"
Tonight, with the temperature below 0 degrees Fahr, I got the following:
"1/16/2009","7:22:16 am","W800RF32","Debug","W800 received raw data [3f 30 05 fa]."
"1/16/2009","7:22:16 am","W800RF32","Warning","W800 has received an invalid housecode value [0x5]"
Here's the rest of X11 security commands courtesy of MisterHouse (see 20/21 vs. a0/a1 in particular):
# Map of security codes to class:function identifiers.
my %scodes = qw(
00 Sensor:AlertMax 01 Sensor:NormalMax
02 Sensor:AlertTamperMax 03 Sensor:NormalTamperMax
20 Sensor:AlertMin 21 Sensor:NormalMin
22 Sensor:AlertTamperMin 23 Sensor:NormalTamperMin
30 Sensor:Alert 31 Sensor:Normal
32 Sensor:AlertTamper 33 Sensor:NormalTamper
40 System:ArmAwayMax 41 System:Disarm
42 Control:SecurityLightsOn 43 Control:SecurityLightsOff
44 System:Panic
50 System:ArmHomeMax 60 System:ArmAwayMin
61 System:Disarm
62 Control:LightsOn 63 Control:LightsOff
64 System:Panic
70 System:ArmHomeMin
80 Sensor:AlertBattLowMax 81 Sensor:NormalBattLowMax
a0 Sensor:AlertBattLowMin a1 Sensor:NormalBattLowMin
c0 System:Panic
vc
