Unable to open Trace file, access denied
Thales
Post by Thales »
I created I Zwave interface, I used a little, but when I tried to creat O All Off cene, the sistem stop working And now when I try to enable Zwave Interface, I recieve the messege bellow?
Unable to open Trace file[C:\Program Files\HouseBot\Logs\InterfaceTrace.Weekly.Feb 15 2009.csv].Error= access is denied
Locking for this way I do not have the Weekley.Feb 15 2009.csv
What can I do?
Re: Unable to open Trace file, access denied
Not sure exactly why the log is opened. If you were viewing the log in another application this can be the cause.
Try stopping HouseBot and see if you can delete (or rename) the log file and then restart it. If you don't need to use the trace data, I'd suggest disabling the hardware interface trace so this won't be an issue.
