Hey all,
My first plugin for HouseBot.
Made in VB.Net so you're going to need the DotNet bridge from this post :
viewtopic.php?f=4&t=856395
The plugin is for a Velleman USB Experiment Interface Board ( http://www.velleman.be/ot/en/product/view/?id=351980 )
The plugin will give you control over :
8 digital outputs
5 digital inputs
2 Analog outputs
2 Analog inputs
Next plugin in the make : Active RFID
http://www.ananiahelectronics.com/RF8315R.htm
http://www.ananiahelectronics.com/RF8315T-x.htm
Have fun with this one
LostDreamer
Velleman K8055 / VM110
- HB k8055-vm110.zip
- (5.29 KiB) Downloaded 1381 times
Re: Velleman K8055 / VM110
Nice work!!
How are you coming along with the Active RFID plugin? Any progress?
The active RFID stuff could be implemented using only the generic serial device - I've been thinking out getting a few to play with. I've used a Maxbotix ultrasonic sensor which reports status in a similar fashion using the generic serial device.
I have been trying to get this to work without success.
How do i install the plugin and get this to work?
thanks
thanks
Hi Raptor,
I just saw your private message...
I think the problem is in the API (I see I forgot to mention it in my previous post)
Attached is the DLL file that should be anywhere in your PATH (ie. windows system32 folder)
When you put it in there it should work.
Let me know if it works with the API, if not, I'll see what I can do.
LostDreamer
ps. About the ActiveRFID is something I put on hold for now, the domoticaforum had a few for tests but they proved to be a bit unstable (they can stop for up to a few hours)
I might try it somewhere next month anyway but can't promosie anything...
LostDreamer
- K8055D.zip
- K8055 / VM110 API dll
- (10.03 KiB) Downloaded 1302 times
That did the trick thanks!
it crashed the 1st time but now it seems stable :) thanks
raptor
raptor
Hi, does this plugin also work with Velleman K8056 with RF option? Thanks.
I dont think so, the K8055 and K8056 have different communication, and different specs.
Regards,
LostDreamer
Regards,
LostDreamer
