SWRemote on Win CE .NET 4.2 Pro
wallebalboa
Post by wallebalboa »
Hi.
I am trying to run SWRemote on a E1101
416 MHz RISC CPU (Intel Xscale)
http://www.mitsubishi-automation.com/pr ... e_1000.htm
http://automation.beijer.se/web/web_aut ... 15004B34B0
i am totally new to CE so i might do lots of wrongs here ;)
the device is labeled WIN CE .NET 4.2 Pro
what i do is making a bat file that copying SWRemote.exe to \ of the device
and try to run it from there.
but i get "Cannot execute \SWRemote.exe" with all the arm clients.
is this a supported device?
am i doing something totally wrong?
my device is having the beijer version of firmware, i will try to get the mitsubishi ...
any advice apreciated, its a great device and so pitty if i dont get it running SWRemote ;(
kind regs anders
wallebalboa
Re: SWRemote on Win CE .NET 4.2 Pro
Hi.
Ok no answer... :? I know there is an old thred from 2004 about this but it gets me no smarter;)
so i try to fill in some more... i found this:
http://www.hpcfactor.com/support/cesd/d/0004.asp
is the CE5 version compiled for xScale (arm5 or arm4) can i expect it to run?
if not, can it be done?
pls help out with some info on if someone have it running on xscale and .NET
kind regs Anders
Anders,
I would suggest trying all of the MIPS remotes and see if they will work. RISC on .net v4.2 seems to be an odd combination, so there may actually not be a remote that will run on it.
