web server IP port
save
web server IP port
Post by save »
How Is possible configure the ip parameters (gateway Ip, http port, etc) in the housebot web server to access using software remote from a remote LAN.
Regards, Miguel Arcas
save
Re: web server IP port
Post by save »
Please,
Answer me, is possible using Software remote through internet?
How must we configure the gateway IP, and the connection port ?
Regards
save
http://www.cebotics.com/forums/viewtopi ... 1&t=856580
This was on page two of this forum. Top left of the page has a text box for searching.
save
Post by save »
Osler,
Does the HB server always run with the port 5015, or is it possible to change it??
Thanks, save
It's always 5015 internally, but using your router's configuration you can specify whatever external port you wish. Refer to you router's documentation for that.
Nightrader_
Post by Nightrader_ »
Taken from the HoueBot help file:
To change the port number on the HouseBot server machine:
  • 1. Start Regedit on the HouseBot machine.
    2. Navigate to HKEY_LOCAL_MACHINE\Software\CeBotics\HouseBot\Configuration Settings
    3. Create a new ‘DWORD’ value registry entry with the name “Server Port”.
    4. Assign it the value of the new port.
    5. Restart HouseBot.
To change the port number on the Software Remote machine:
    2. Navigate to HKEY_LOCAL_MACHINE\Software\CeBotics\HouseClient\Configuration Settings
    5. Restart the Software Remote.
