GC-100 ir code not working
Autodomain
Post by Autodomain »
I have strange problem using GC-100 and remote pronto code.
Briefly, I have 4 pronto code and only 1 is working with housebot other 3 give me an error about compilation prontocode, but all 4 pronto code is working with global cache utility.
It is the first time I use IR in housebot, somebody have an idea ?
Autodomain
Re: GC-100 ir code not working
Scott !! Please help me
This is the pronto code:
0000 006C 0022 0002 0157 00AC 0014 0014 0014 0041 0014 0041 0014 0041 0014 0041 0014 0041 0014 0041 0014 0014 0014 0041 0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 0041 0014 0041 0014 0041 0014 0041 0014 0041 0014 0041 0014 0041 0014 0041 0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 0014 0041 0014 05F6 0157 0057 0014 0E56
0000 006C 000C 0012 0008 0022 0008 0032 0008 001D 0008 006C 0008 0032 0008 0032 0008 002D 0008 0022 0008 01F3 0008 0022 0008 001D 0008 001D 0008 001D 0008 001D 0008 006C 0008 001D 0008 001D 0008 0BFE 0008 0022 0008 0032 0008 001D 0008 006C 0008 0032 0008 0032 0008 002D 0008 0022 0008 01F3 0008 0022 0008 0047 0008 0047
One code is working the other not working.
Both code is workin using global cache utility .
Thanks in advance .
Not sure why that would be. What is the error it give you?
Autodomain
When I try to test the code I get two errors "Unable to convert Pronto code to GC-100 code." and "Error transmitting IR Code to GC-100"
Can I use the GC-100 format code like this ?
38000,1,1,8,34,8,50,8,29,8,108,8,50,8,50,8,45,8,34,8,499,8,34,8,34,8,29,8,29,8,29,8,103,8,29,8,29,8,3070,8,34,8,50,8,29,8,108,8,50,8,50,8,45,8,34,8,499,8,34,8,76,8,71 .
You can't use that format.
What device are you trying to control?
Have you gone to www.remotecentral.com to see if they have a working pronto code for your device? You can use CCFViewer to open CCF files in xml format to get at the pronto codes.
Are these learned IR codes? If so, have you tried relearning the code?
Autodomain
A samsung TV and Yamaha amplifier
Have you gone to http://www.remotecentral.com to see if they have a working pronto code for your device? You can use CCFViewer to open CCF files in xml format to get at the pronto codes.
Yes I took the code from there, but nothing work .
No its not learned.
All the code I try does not work at all.
I have 2 computer with 2 housebot installation and 2 global cache GC-100 .
Do You have some working code that I can try.
I can post discree on/off for my Samsung DLP and Yamaha Aventage receiver tonight.
I will also try putting your pronto codes in my system to see what happens.
Also, make sure you don't have something else accessing the GC-100. It can only handle one connection at a time. The newer iTach series can handle up to 8 simultaneous connections.
Samsung On:
0000 006d 0000 0022 00ac 00ac 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0689
Samsung Off:
0000 006d 0000 0022 00ac 00ac 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0689
Yamaha On
0000 006d 0022 0002 0155 00aa 0016 0014 0016 003f 0016 0014 0016 003f 0016 003f 0016 003f 0016 003f 0016 0015 0016 003f 0016 0014 0016 003f 0016 0014 0016 0014 0016 0014 0016 0014 0016 003f 0016 003f 0016 0014 0016 003f 0016 003f 0016 003f 0016 0014 0016 0015 0016 0015 0016 0015 0016 003f 0016 0015 0016 0015 0016 0015 0016 003f 0016 003f 0016 003f 0016 05e6 0155 0054 0016 0e39
Yamaha Off
0000 006d 0022 0002 0155 00aa 0016 0014 0016 003f 0016 0015 0016 003f 0016 003f 0016 003f 0016 003f 0016 0014 0016 003f 0016 0014 0016 003f 0016 0014 0016 0015 0016 0015 0016 0015 0016 003f 0016 0015 0016 003f 0016 003f 0016 003f 0016 003f 0016 0015 0016 0015 0016 0015 0016 003f 0016 0014 0016 0014 0016 0014 0016 0014 0016 003f 0016 003f 0016 003f 0016 05e6 0155 0055 0016 0e39
I also tested your above pronto code (first one) and get the same error. There is definitely something wrong with the pronto code.
For some reason, I was not able to reproduce the error you see with those codes. Not sure why that would be.
The only way to receive the "Unable to convert Pronto code to GC-100 code" error is if the validation logic for the pronto code fails. The validation logic goes, basically, like this:
  • Make sure each character in the code is 0-9 OR a-f OR A-F
  • Space between the codes (only space, no line feeds allowed)
  • Make sure the length of the full code string is at least 29 digits
  • Make sure the length of the full code string is not greater than 1229 digits
  • Make sure the individual codes are in groups of 4 digits
One thing that will cause the code to fail the test is if you have a line feed at any point in the code (including the very end). So make sure the code is one long line with and remove all spaces and line feeds from the end of the code.
Autodomain
The pronto code from Osler working good .
I have noticed that my pronto code have 4 chr at beginning and 1 chr more at the end, I have stripped that chr and now my pronto code is working.
As can be seen in the screenshot the problem seems to be solved.
Thanks to Osler and Scott
