W7 Gestures
W7 Gestures
The other day I was looking at new touchscreen devices and found that Multi touch W7 compatble 4:3 15, 17 or 19" touchscreens aren't that expensive anymore.
If HouseBot had a plugin that read the W7 or W8 gestures and provide these gestures in a property, lots of good stuff could come from that.
Let's say a gesture engine is running in the background and recognizes double fincger tabs, swipes left and right, zooms etc. If these gestures would be made available in ascii form in a property, this property could be read and dealt with.
Example: A movie panel containing movie covers is currently the visible theme panel. There are buttons to inc or dec the list... these buttons could be simulated now by gestures. A swipe down gesture is read, the current panel is movies so the command would be: next 15 covers..
This could be built as a separate C# or C++ mudule running outside of HouseBot but it would not be a lot of work to make it native to HouseBot as far as I can see. It would open up lots of new stuff though without having to rebuild the complete SWRemote.
Any thoughts??
Re: W7 Gestures
You're suggesting to implement it as a module? Wouldn't this need to be something built into the SWRemote and not the server?
Re: W7 Gestures
In the remote would be the ultimate solution but I guess that means a complete overhaul of the remote and I don't see that happen any Time soon..
But as a selectable device in the HouseBot server lot's of functionality would become available and with very Little effort I suppose.
