insteon sensor question
boyakaa
Post by boyakaa »
Hello all,
new to Housebot (on 30 day trial), my question is. When i go to create an insteon device, it has an option for insteon switches and dimmers. But i do not see an entry under new devices for insteon sensors.
Are insteon sensors supported?
Using
A USB based plm and wireless access point for insteon.
Switch automation work just fine.
Re: insteon sensor question
Insteon sensors are not specifically supported, but you might want to try just configuring an insteon switch device using the sensors address and see if it's Power State property follows the sensor state.
If that doesn't work, I'm pretty sure I could add the support easily (just need a sensor).
boyakaa
Post by boyakaa »
You are correct it does work as you mentioned. Thank you
