Hi Scott,
I am interested in this product: http://media.lodestar.be/intellihome/manuals/LWM1.pdf
It is a 2 way dimmer. It can send it state to other X10 devices.
What I want to know is: will it send its state back to the CM11 interface? Will I be able to know from HB if someone has (for example) switched the light on with a external momentary switch? Or it only will send the state to other receivers?
Thank you very much,
Dakkar
2 way switches and HB CM11 interface
Similar to this:
http://www.simplyautomate.co.uk/product ... rodId=5456
I have a few of these installed and also use Momentary Switches (Bell Push Modual switches)
I can turn lights ON/OFF and DIM via the Momentary Switch and via HB.
I wouldnt have thought so. I dont think the HDM1 receives and SENDS information.
If the device you were looking at states that it DOES send and receive information then it MAY change the status in HB.
But i am unaware.
Im not fussed if my momentary switch alters HB as i can tell if a light is ON or not.
Ahhh i just saw the bit from you that says it sends its state. So i would have thought it would alter HB.
But i am unaware.
Re: 2 way switches and HB CM11 interface
I can't say for sure, since I'm not familiar with those particular devices. However, the HouseBot CM11a Hardware Interface DOES support 2-way X10 commands. So if the switch sends an A;1;On (for example), HouseBot will change the Power State of any X10 Device setup as A;1 to "On".Dakkar wrote:Hi Scott,
Dakkar
