File not found[/CheckVersion.asp?pcode=22&sver=2.30]
The above error shows now and then. No clou why?
I installed HB 2.30 in the original Meedio HouseBot directory and ran the upgarde.exe
kilowatt
Post by kilowatt »
I saw the same error yesterday. I suspect it has to do with automatic software update checking. I get the same error if I select 'Check for software updates' in the help menu.
Yep, same here when checking for new software. I never actually did that since it is flagged as auto check in the Program Options. The error occured right after start up, so that must be it. Nice knowing what it causes... Thnx
It was a web server/DB problem. It's fixed now.
Be carefull Scott with fixing stuff so rapidly. We could get used to that;)
