File not found[/CheckVersion.asp?pcode=22&sver=2.30]
The above error shows now and then. No clou why?
I installed HB 2.30 in the original Meedio HouseBot directory and ran the upgarde.exe
I saw the same error yesterday. I suspect it has to do with automatic software update checking. I get the same error if I select 'Check for software updates' in the help menu.
