Windows 7
tuggybear
Windows 7
Post by tuggybear »
Under Windows 7
The Wizard boxes do not properly display.
They open but the content of the box is larger than the box and you cannot scoll
Re: Windows 7
I'm not seeing that here. Which wizard(s) are you seeing it with? Also, is your display size set to 100% (smaller), or did you change it to the larger setting?
Re: Windows 7
I see this on Windows XP as well (reported over a year ago :D ). It's a hindrance but you can still complete the wizard...just use the return button since you can't click the OK button. I think it's a screen resolution problem as opposed to an OS specific problem.
tuggybear
Re: Windows 7
Post by tuggybear »
That fixed it thnks
